Some questions about Trail Balzer.
Old Oct 29, 2000 | 11:27 PM
nauvooguy's Avatar
I was wondering where the idle is located on it,and also what type of chain lube you use.
Old Oct 31, 2000 | 06:22 PM
waynaferd's Avatar
The big phillips head screw underneath the carb (has a knurled head so you can use your fingers) is for the idle. look down under the left side(while sitting on it), and you can't miss it back and above the clutch cover. Just make sure your bikes warmed up, as it should idle high when cold. As for chain lube, use any that's made for o-rings (o-ring safe) I use klotz chain lube. Very sticky. just ride your wheeler around for a few minutes to warm up the chain, and the lube will penetrate better. Enjoy your wheeler!!!
Cole Hadden
Jun 15, 2025 09:05 AM
coolguy420
Jul 28, 2015 01:54 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
tporath
Jul 11, 2015 12:31 PM
yambam13
Jul 4, 2015 01:49 PM
