hard to start 250x
Old Nov 8, 2005 | 10:46 PM
gtay48's Avatar
Default hard to start 250x
I am having a problem with my 92 250x. I bought it used about a month ago. It ran strong ans started easy. All of a sudden, it became hard to start. When I do get it started and warm, it idles fine. It also seems fine through about 1/4 throttle. After that it starts to sputter. If I ride it, it will not take any gas after 1/4 throttle. I can't find anything wrong. I have gone through the carburator and replaced the split fire spark plug with stock NGK. Anyone have any suggestions?
Old Nov 8, 2005 | 11:12 PM
250sxkid's Avatar
you got a problem with gas flow if its too dard to start lift it straight in the air till u see gas comming out of overflow if it starts easyier then thats the problem
Old Nov 9, 2005 | 09:32 PM
gtay48's Avatar
You were right! thanks for the tip! I took apart the fuel shut off valve and found a piece of hardened crud in the bottom of the cap. it must have been blocking the flow. reinstalled everything and it runs like a charm again.
Old Nov 10, 2005 | 09:07 AM
250sxkid's Avatar
glad to be of service if u have any more probs let me know
Old Nov 10, 2005 | 05:52 PM
gtay48's Avatar
OK, I guess I spoke too soon. I am still having a hard time getting it started. the 1/4-full throttle problem was it not getting enough gas.
what happens now is it is cold, i attempt to start without the choke and get no response. I then close the choke and still nothing. at this point i am starting to smell gas. all it will do now is seem like it is going to start (let off a few rumbles of the motor). This happens if the choke is on or not.
so again, I need help... any ideas?
Old Nov 16, 2005 | 12:04 AM
250sxkid's Avatar
mine does that too it takes up to 20 kicks sometimes when its cold and when it does start its like it doesent get gass and almoast shuts off but when it warms up its fine i think we both have a compression prob check your gaskets and exhaust flange (could be lose)mines bad 2 so that could be it
Old Nov 16, 2005 | 12:09 AM
250sxkid's Avatar
also try slowly depressing the kick starter 2 or 3 times prior to giveing her a good boot in order to build up compression should make a big diff if you do have a compression leak . check the specs for your bike and get a compression test meter just to be sure good luck
Old Nov 18, 2005 | 04:47 PM
gtay48's Avatar
I think you are right about me having a compression problem. I have not had a chance to put a meter on it though.
when i kick it and let go of the kick start lever right away, it seems like it wants to actually start. one night this week, i got it to start this way. I was wondering if it has something to do with the decompression mechanism. i read some where online that someone disconnected it. could it cause this problem? I looked in my repair manual and it doesn't say how this should work. all it explains is how to inspect it when rebuilding the engine.
Old May 10, 2006 | 03:07 PM
gotanswers's Avatar
clean carb your floats are sticking when they stick shuts off gas flow or if stuck open getts to much fuel and floods out which will soon fowl plug. try tapping on carb slightly with wrench with seat off of corse sometimes this unstick floats if it starts clean carb cause you dont want to cut off way back in woods do it right so your safe riding. you also might need new timing chain if slack in chain can sometimes throw off timing
Old May 10, 2006 | 04:47 PM
gtay48's Avatar
The problem was solved in December. I changed the ignition module. Runs perfect now. Thanks for the suggestions though.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
1000gade
May 27, 2015 12:37 PM
Wils400EX
Oct 14, 1999 04:57 PM
dunc_n
Aug 26, 1999 09:32 PM
