400ex neutral light
i have an 04 400ex and it wont start unless it's in neutral..I.E. the neutral light has to be on. This is a pain in the @** when trail riding. Can I bypass that light and make my quad start when I pull the clutch, regaurdless of the gear????
Hmmm... my 99 starts in gear when I pull the clutch in, are you sure yours will not do the same? Look at your clutch lever. If the 04 is like the 99's it will have a switch on it, and if it does then there must be a problem with the switch.
You cant really see the switch but you should be able to see 2 wires going to a little black rectangular box on the clutch perch. You should also be able to hear a little click when the clutch is pulled in as well as the switch trips. Maybe they removed it for some reason, Ill look on bikebandit.com and see but I bet yours is just not working.
Yeah yours should have it unless you have something other than a stock perch that has been changed out. It is item # 5.
http://houseofmotorcycles.bikebandit...TRAX+400EX.asp
take the 2 wires going to the clutch perch off and hook them together with a jumper wire and see if it will start in gear then. MAKE SURE U PULL THE CLUTCH WHEN YOU TURN IT OVER. i know it sounds stupid but i had the same problem and got so frustrated i forgot to do just that bc i was holding the wires with my clutch hand. straigt into the back of pops HD. i felt like the biggest jackass ever!!!
