400ex neutral light
Old Nov 9, 2005 | 10:02 PM
Robash's Avatar
Default 400ex neutral light
i have an 04 400ex and it wont start unless it's in neutral..I.E. the neutral light has to be on. This is a pain in the @** when trail riding. Can I bypass that light and make my quad start when I pull the clutch, regaurdless of the gear????
Old Nov 9, 2005 | 10:11 PM
LTRACER's Avatar
Hmmm... my 99 starts in gear when I pull the clutch in, are you sure yours will not do the same? Look at your clutch lever. If the 04 is like the 99's it will have a switch on it, and if it does then there must be a problem with the switch.
Old Nov 9, 2005 | 10:15 PM
Robash's Avatar
yea. I've tried a million times to get it to fire over in gear by pulling in the clutch, but it won't work. What does the switch look like on the clutch?
Old Nov 9, 2005 | 10:21 PM
LTRACER's Avatar
You cant really see the switch but you should be able to see 2 wires going to a little black rectangular box on the clutch perch. You should also be able to hear a little click when the clutch is pulled in as well as the switch trips. Maybe they removed it for some reason, Ill look on bikebandit.com and see but I bet yours is just not working.
Old Nov 9, 2005 | 10:25 PM
LTRACER's Avatar
Yeah yours should have it unless you have something other than a stock perch that has been changed out. It is item # 5.
http://houseofmotorcycles.bikebandit...TRAX+400EX.asp
Old Nov 10, 2005 | 12:53 AM
TheTurtle's Avatar
take the 2 wires going to the clutch perch off and hook them together with a jumper wire and see if it will start in gear then. MAKE SURE U PULL THE CLUTCH WHEN YOU TURN IT OVER. i know it sounds stupid but i had the same problem and got so frustrated i forgot to do just that bc i was holding the wires with my clutch hand. straigt into the back of pops HD. i felt like the biggest jackass ever!!!
Old Nov 10, 2005 | 07:50 PM
Robash's Avatar
i tried it. no good. I found the switch and it clicks when I pull in the clutch lever. I don't know. the part is only 12 bucks. i'll buy one and try it.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
JoAnnS
Jul 23, 2015 02:18 PM
