Adjustment for clutch?
I was wanting to know if there is an clutch adjustment for the 2000 honda rancher? And if so where is it located? When i change gears it go right into the next gear. I thought as long as you held up on the shifter it would stay in like a neutral state tell you let off? mine does not do that. you have to have the RPM's just right also before it will change to the next gear. Any help would be good.....Thanks....
