2001 400EX Gearing (Sprockets)...
Old Nov 13, 2005 | 01:51 PM
ThaChad's Avatar
Default 2001 400EX Gearing (Sprockets)...
Hey All,
My 2001 400EX doesn't have 1/2 the torque as my 2004 Z400, I usually just wright it off as being aged, which may or may not be part of the problem...
But today I looked up the Sprockets on the 400EX, it looks like the Front Sprocket is a 15tooth, and the Rear Sprocket is a 38tooth. On my Z400 the stock gearing is 14tooth front, and 40tooth rear.
Is that why my Z400 has soo much more torque? Or is the gearing inside the transmission different?
I just ordered a 13tooth front sprocket for my Z400, to give it even more torque for Dunes, and trails.
What type (Size) of sprockets does everyone run on their 400EX?
Thanks,
-ThaChad
Old Nov 13, 2005 | 02:51 PM
TractorPacker's Avatar
Do you have a balloon?
I run 16/39 most of the time on the EX.
Old Nov 13, 2005 | 04:29 PM
ThaChad's Avatar
Wow, The transmission internal gearing on the 400EX must be ALOT different that the Z400...
Gearing like that on a Z400 would be soo slugish on the bottom end.
-TheChad
Old Nov 13, 2005 | 10:33 PM
Wheelerbob's Avatar
The stock gearing on the 99-04 400 ex is 15/38, if you run 14/39 it will rip like a hole new machine, I went to 14/39 and it was amazing the difference in bottom end, it did lose a bit on top end but i trail ride so top speed means nothing to me, I have since switched to 22" rear tires and dropped to 13/39 and it is about the same as 14/39 with 20" tires. The factory gears the 400 more for top speed, remember the 400 was originally designed as a race machine and not a trail machine, but with a little gearing change the difference is night and day.
Old Nov 14, 2005 | 02:36 PM
400EXtreme1's Avatar
how much of topspeed are u talkin about.
Old Nov 15, 2005 | 11:13 PM
Wheelerbob's Avatar
5-7 mph
Old Jun 17, 2015 | 09:49 PM
Corder33's Avatar
I have an 01 400ex and the sprocket sizes on my quad are 13/37. What could this ratio be used for? How do you think I should change it to have decent torque and gain a little speed?
Reactant
Mar 30, 2022 02:08 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
maxjung
Jul 14, 2015 03:10 AM
