help Starting 250x
Old Nov 16, 2005 | 12:00 AM
gtay48's Avatar
Default help Starting 250x
My 250x is only about a month old to me. It ran great for the first two weeks then it became hard to start. I know I was having a problem getting fuel. Since then I have cleaned out the fuel shut off valve and don't think that is the problem. Typically I can start it about every 2-3 days when it fires up first kick. once it is started, it runs fine and i can start it again as long as it is warm. the day after i can try forever and it acts like it should start, but doesn't. I have tried starting fluid and still nothing. I need help! anyone ever had this happen? any ideas?
Greg
Old Nov 20, 2005 | 10:47 PM
87250xman's Avatar
I had trouble like that and it turned out to be the CDI. But before you do that try cleaning your fuel tank and the carb.
Old Nov 21, 2005 | 02:41 PM
hondabuster's Avatar
Next time its having trouble starting, pull out the spark plug and check for spark. If you have spark, then you either have a compression problem or a fuel problem.
big_g_squared
Jun 28, 2015 04:17 PM
1000gade
May 27, 2015 12:37 PM
owen350x
Jul 30, 2000 01:58 AM
97TrailBlazer
Apr 2, 2000 03:34 PM
YellaTerra
Mar 30, 2000 04:38 PM
