big red carb problems
Old Nov 16, 2005 | 11:03 PM
ALdarkcloud36037's Avatar
Default big red carb problems
i have a 84 honda 200es big red, it idles like crap, i have cleaned the carb twice, no change at all, i noticed the manual i have said that the pilot jet nedds to be 1 7/8 turns out, what does this mean, or would a kit help and where could i get one, thanks for
Old Nov 17, 2005 | 02:45 AM
ThrashAndCrash's Avatar
Screw the pilot jet in until it lightly seats, then back it out 1 7/8 turns. And yes a kit may help you out
Old Nov 17, 2005 | 09:32 PM
i have cleaned it out twice, no better at all, you can pull the adj. screw completly out and it runs better, im kinda baffled by this one, thanks for the reply
Old Nov 18, 2005 | 03:16 AM
250sx's Avatar
I think those have a little short intake manifold between the carb & cylinder right? use some spray carb cleaner or starting fluid while it's running to check for air leaks. also, even if you've cleaned it up there could still be some really gunked up stuff in the tiny passages in the carb. see if you can find a known good one to try or get some really small wire to try and help clean them all out.
Old Nov 18, 2005 | 09:33 AM
im almost positive there is nothing stopping it up, if it idles for a little while it floods out, you can take the plug out, clean it, put it back in and it fires right up, you recon it could be the coil getting weak
Old Nov 18, 2005 | 04:44 PM
kev74's Avatar
My 110 ATC is doing the same thing. The previous owner removed the mix and idle screws, and it ran ok. My guess is that its getting too much gas due to wear in the carb, and have a rebuild kit on order. I'll post how it works out.
Old Nov 20, 2005 | 12:24 AM
3wheelerdude's Avatar
Definitely get a carb kit, it should solve your problem.
Old Nov 20, 2005 | 12:52 AM
okay, thanks i will try it, i just hope thats the problem
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
