Help with 400ex Not starting too cold?
Old Nov 19, 2005 | 06:18 PM
monster88's Avatar
Default Help with 400ex Not starting too cold?
Whats up. I have a 2001 400ex. It runs fine, was just using it on the street yestuday. I started it up today and it ran fine. I was outside all day so about 4 hours later i tried to start it again, and it did not run. Made sure the gas was on, choke was on and everything. Its about 30 degrees F here. Is it too cold? Im going upstate riding this week so i need to know if its just too cold or is it something else? When im cranking it, it cranks fine, no weird sounds at all. Thanks
Old Nov 19, 2005 | 07:19 PM
hondabuster's Avatar
The mixtures do get leaner as the temperature falls.
But if it sat for 3 hours, and now wont start...it could be a few things.
Sometimes holding the throttle at a steady 1/4 open, choke on and crank , will get it started if its really cold.. If it doesnt start after a few tries, try a new spark plug.
If its not too cold on the rider, its not too cold for the quad.
Old Nov 19, 2005 | 10:33 PM
TractorPacker's Avatar
Do you have a balloon?
I say try a new spark plug,also.
Old Nov 19, 2005 | 11:29 PM
TRX6702's Avatar
Also check to make sure the plug wire coming off the coil is pushed onto the coil all the way.For some reason thats was the problem with mine once and I never even touched it.Pushed it on tight and it fired up after a couple cranks and I have my choke taken out.Im also in cold weather being in upstate NY.
Good Luck
Ron
Old Nov 21, 2005 | 12:41 AM
motion's Avatar
did you make sure the kill switch is not on ?
Old Nov 21, 2005 | 01:34 PM
TheTurtle's Avatar
im gonna say plug as well...i started my quad one day to load it...got to the park (bout 45 mins later) and it wouldnt start to save my life. after driving around for an hour i found someone that had a plug and it fired right up!
Old Nov 21, 2005 | 02:09 PM
That one catches all of us at one time or another. Good suggestion.
Old Nov 21, 2005 | 10:29 PM
Lighthouse's Avatar
Also don't forget that each Honda Quad has three ( 3) different spark plugs
Summer.........Winter........and High speed !!
John
Old Nov 25, 2005 | 12:56 AM
monster88's Avatar
Hey guys whats up. It was the sparkplug. It was all full with carbon. I cleaned it off with a file, gapped it right, and it started right up. Thanks for the suggestions.
Old Nov 25, 2005 | 09:33 AM
moppy's Avatar
the damn things dont start in the cold i tried to start mine on the weekend i was out there for an hour. i just gave up and put in the garage.
