Blew a hose changing the oil...
Old Nov 19, 2005 | 10:03 PM
Jayblazer's Avatar
Default Blew a hose changing the oil...
went to prime the oil pump and i could not get it to hiss on the third try the hose blew apart
where did i go wrong? was the oil pump still primed? how can i tell if it is primed? man this sucks...
i did not take the hose off the bottom of the oil reservor would that cause it to stay primed?
Old Nov 20, 2005 | 07:11 AM
XShowtimeX's Avatar
Yep I would say the oil pump was primed. NO need to prime if you just change the oil and filter, only time you need to prime is if you remove a hose the owners manual should have clearly stated that.
Old Nov 20, 2005 | 10:31 AM
Jayblazer's Avatar
Ouch insult to injury thanks a lot...
Since I had pulled the pull start several times I thought that I had pumped out all the oil in the system.. But was not sure so I thought better safe than sorry. This was my first time changing
the oil. I was changing it over to 5w50 syntec like cornbread had suggested.
Well if nothing else people in the future who use search can learn from my mistake..
Old Nov 20, 2005 | 03:09 PM
Jayblazer's Avatar
so when i change the hose i will need to prime the pump right??
then just add oil back to the full mark.
Old Nov 20, 2005 | 11:51 PM
cornbread2's Avatar
Right.
Old Nov 21, 2005 | 07:08 PM
Jayblazer's Avatar
the hose that blew is the return hose right. so wouldn’t the pump still be primed?
because the hose blew after the pump. sorry for bringing this back up i just want to make sure i get it right.
Old Nov 21, 2005 | 10:39 PM
spyder6's Avatar
i would guess so
Old Nov 22, 2005 | 03:39 AM
XpLo400's Avatar
so when i change the hose i will need to prime the pump right??then just add oil back to the full mark.
You have to add the oil and then prime the pump...
akguy31
Aug 31, 2019 04:34 AM
bvolks
Sep 13, 2015 12:57 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
