Clutch advise needed
Old Nov 22, 2005 | 04:33 AM
sportsman2004's Avatar
Default Clutch advise needed
So, help me out with understanding what does what on these clutches. I know there are some guys out there that know everything and anything about these clutches.
So, I have a 700EFI. I purchased a BMP Supertip Clutch that allows me to adjust the weights in the form of washers that I can add to the heel, middle and tip. I have it set up right now so it is monsterous and pulls extremely hard up to 40. After that, it falls on its face. I am only taching out around 5400 RPM's. I have the stock spring in there because I like the engagement. I have a spring that I got with the kit that is about 1/2 taller and stiffer (no color, just a green stripe on it). Let me know. I would like to keep the hard pull, but would like to fix the top end.
Old Nov 22, 2005 | 07:07 AM
SPORTSMAN70003's Avatar
Sounds like you might your weights are setup to heavy. How do you have your weights setup and how heavy are they? You should be seeing 6000-6200 rpms at WOT.
Rocketx
Nov 16, 2020 07:25 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
FourWheelOverTwo
May 31, 2015 07:26 PM
