2000 honda Fourtrax 350ES
Old Nov 23, 2005 | 12:03 PM
DOITNEWF's Avatar
Default 2000 honda Fourtrax 350ES
My bike seems hard to push when in neutral.........is this normal?
Thx
John
Old Nov 23, 2005 | 12:18 PM
Prezzz's Avatar
I can tell you that my 2003 Rancher 350 ain't exactly a breeze to push around in neutral, especially if turning. Sounds normal to me.
Old Nov 24, 2005 | 09:10 AM
DOITNEWF's Avatar
Anyone know why they are so difficult to move?
JP
Old Nov 24, 2005 | 05:40 PM
hondabuster's Avatar
Its the combination of full time 4wd (no 2wd option), and the back axle is solid. Theres no other differential other than the front one. No center or rear differential. The right rear tire is locked to the left rear tire, and which ever front tire has the best traction is binding with them. This is where the polaris guys get the 3wd from...3 and only 3 tires are bound together. It will switch from one side of the front to the other, but one is always linked with the back.Turning makes for alot of resistance, because of all the binding .
If it had a center differential or a 2wd switch, it would roll a bit better, but none of the 4x4 utes will roll very well.
If you point it straight ahead, it shouldnt roll too bad, but if it still does...check tire pressure, and for dragging brakes. If the tire pressure is too low, it does increase the effort.
Old Nov 25, 2005 | 12:59 PM
RobGonz's Avatar
it might be hard to push because it weighs 535 pounds. besides, youre supposed to ride the thing not push it.
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
ScopeZ_
Jul 28, 2015 01:44 AM
