scrambler 400 high performance?
Old Oct 31, 2000 | 04:35 PM
scramblered's Avatar
i have a 1999 scrambler 400 4x4 with full race mods run on 105 octane fuel,hsp exterminator race kit and i've blasted 2 engine yet,the engine broke like plate for too high compression,i've bored my motor to .080 also with 14.1 billet heads.it's a blast to ride but it only take 2 hours to broke up!the scrambler 400 is not a high performance quad.
Old Oct 31, 2000 | 05:21 PM
scramdaddy400's Avatar
Did you do the work yourself?
Work like that should be done by engine builders.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Oct 31, 2000 | 09:23 PM
bullgod's Avatar
I wouldnt trust hsp with anything of mine after i had one of there exhuast on my 500 scrambler and it snapped off and rusted and barely added power
Old Oct 31, 2000 | 09:39 PM
RickRitter's Avatar
What kind of carburetor are you using ? How is it jetted ?
It really should run .
Old Oct 31, 2000 | 10:15 PM
RippinScrambler's Avatar
I've never had a problem with my HPD Pipe for my Scrambler 500. It really helped low end power. I would recommend one of those.
Bad spellers of the world untie!!
Old Oct 31, 2000 | 11:17 PM
my carb was a 42mm,and my main jet was for 440 with dually dial-a-jet kit,race lighten flywheel,aggressive clutch kit...
Old Oct 31, 2000 | 11:48 PM
RickRitter's Avatar
A 42 is a modified 38 TMX . On a flow bench it flows no more air than a standard 38TMX.
Do this . Change your needle to a #55 , and drop to a 10 to 15 pilot , and remove the dial a jet , see if that doesn't help things .
Old Nov 1, 2000 | 02:30 PM
thank a lot man,you rule,i'm gonna try this out and see what it sound like!
Old Nov 2, 2000 | 09:23 AM
bullgod's Avatar
Im not talking bout HPD im talking bout HSP it wouldnt of been so bad if they would of stood behind there product.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
1000gade
Sep 9, 2015 03:35 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
