head light mod with relay
Old Nov 26, 2005 | 09:15 PM
24houradrenaline's Avatar
Default head light mod with relay
i decided i want to do the headlight mod but i want to do it with the relay how do you do it? and were and what type of relay do i need.
Old Nov 27, 2005 | 01:02 AM
someone has to know how to do it
Old Nov 27, 2005 | 02:18 AM
UTU's Avatar
UTU
I did this with the diode kit they are selling on e-bay. 5-7 dollars. no cutting wires no soldering and pretty simple. Could not see a reason for a relay. Mine works greatttt! Take Care!
Old Nov 27, 2005 | 03:21 PM
hayride's Avatar
I did it last weekend with the relay and this is the info I got from a prior thread (3 light mod dated 30 July 05)... It worked out great.
You will need to purchase a standard 4 pin, 12v relay, 4 pieces of 16 gauge wire about 8" long, 4 female crimp on spade connectors (for connection of wires to relay), 4 wire splice connectors.(they are usually blue and you simply insert the wires and squeeze with pliers, then fold back the protective locking cover)
Open the pod and locate the wiring listed below
Relay terminal #30 connects to Polaris green wire (low beams)
Relay terminal #87 connects to Polaris red wire (10 amp protected circuit at the lighter plug)
Relay terminal #86 connects to Polaris wire yellow wire (high beam)
Relay terminal #85 connects to Polaris brown wire (ground)
Use dielectric grease or liquid tape at all electrical connections to prevent corrosion.
They way this functions, is that when you select high beam, you are powering up the relay to give 12v to the low beam circuit from Polaris's 10amp 12v protected circuit. (No fuse needed) Enjoy.
Bulgin88
Aug 1, 2015 06:39 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Bratman2
Jul 23, 2015 12:36 PM
cornermike
Jul 8, 2015 11:44 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
