400EX Rear Bearings
Old Nov 27, 2005 | 01:19 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 400EX Rear Bearings
My bearings are toast on my 400EX. No small wonder, the bike is 7 years old and has hundreds of hours on it. I should have done them long ago, but let it get bad enough that the bearings got hot on the last ride and now the axle wobbles a little.
So, my question is do you think I did some real damage by neglecting it so long? What am I in for if I really totally toasted them???
Old Nov 27, 2005 | 02:20 PM
Tator397's Avatar
i've not had this prob yet but my lil bro has. we replaced his it wasnt that bad, took longer for the parts to get there than it did to fix it. DO NOT BUY another OEM part, try to go after market if possible. i cant exaxtly remember what type a he bought and price, it was bad priced. whenever you got to take the nut (the inner axle lock nut) it real tight so you need a good sized breaker bar. it is has left handed threads. be sure and tighten it back upto 65 ft lbs. get a haynes book from your local shop those things are awesome, a hayens manual is great. we've owned one for every rcuk, four wheeler, dirt bike we've ever owned.
after you've taken off the axle lock nut, you'll need a set of snap-ring pliers. or a set of real fine point needle nose pliers.
Old Dec 10, 2005 | 08:02 AM
Red Rider
The carrier is damaged as well as the axle. Will cost some $$$.
Going with a Lonestar 4 bearing carrier (instead of the stock 2 bearing) and a Durablue axle.
Thinking back, I got caught in a desert flash flood last winter. Had to do quite a bit of riding in dirty water with fine silt and sand in it, and that is when all my problems began!
Old Dec 10, 2005 | 10:08 AM
quad2xtreme's Avatar
wow, 7 years are on a set of axle bearings. That would be nice. I get about a year.
Old Dec 11, 2005 | 01:06 PM
TractorPacker's Avatar
Do you have a balloon?
The dual row carriers are nice, but have you considered tapered? I personally like setting the pre-load on a wheel bearing.
Old Dec 11, 2005 | 03:05 PM
DuneRider650's Avatar
I ride a little here and there......
tapered bearings are awesome...atleast after going through axle bearings on the warrior which werent tapered ill never go back.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
STLyamwar
Jul 25, 2020 04:44 AM
Asaran
Oct 8, 2015 11:14 AM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
Peter_
Jul 18, 2015 07:06 AM
