250x trouble again
Old Oct 31, 2000 | 09:38 PM
BlasterBOY6969's Avatar
MY 250X IS HAVING SOME TROUBLE.ALMOST EVERYTIME I RIDE IT IT DIES ON ME.IT USUALLY DOES IT ON MY FLAT TRACK,I GET IT IN 3RD GEAR AND POWERSLIDE OUT OF THE CORNER AND WHEN I GET OUT OF THE CORNER IT DIES.SO HELP.
Old Oct 31, 2000 | 10:49 PM
FireBug's Avatar
You are probably in too high of a gear. You should down shift or try a new plug. The gas filter could also be clogged. Check those things out and tell me if any of those worked.
Old Nov 1, 2000 | 01:08 AM
kickAZZ250xer's Avatar
ya probaly just to high of gear. just pull in the clutch. when it starts to die.
maybe be the plug or soemthing mechanical
Old Nov 1, 2000 | 03:56 PM
94DGblaster's Avatar
sure sounds to me like you need to learn how to downshift..! Just messing with you
Check plug, air filter, loose wire connections..something could bang around when you hit the corners.... I can't really think of anything else
Old Nov 2, 2000 | 04:57 AM
puddding's Avatar
i have experienced similar problems
not this downshifting stuff.......still haven't had time to much around and fix the problem
riding on the left two wheels, will cause it to bog
where as riding on the right two doesn't cause any problems
hmmmmm......
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
