Kazuma 110 chain and sprocket
Old Nov 28, 2005 | 11:22 PM
submakr's Avatar
Default Kazuma 110 chain and sprocket
I want to replace my stock front sprocket from a 12T to a 11T. Is an 11T available and what is the chain pitch?
Thanks for the help.
Old Nov 29, 2005 | 11:14 PM
RacewayATV's Avatar
I am sorry I do not know the answer to this question, but I will see what I can find out for you. Might take me a day or two or maybe someone else will post faster then me, the guys in this forum are great! most time they reply before I even get to them!
Mini ATV Raceway ATV
Old Dec 13, 2005 | 12:28 PM
submakr's Avatar
I figured out that the chain size is a an incredible 530!! I wonder why they used such a large size. That is normally for 1000cc plus motors. A 520 would have been perfect.
Old Jan 16, 2006 | 12:04 AM
conan2005's Avatar
Im also looking to repalce the sprockets on my kids kazuma, did you ever find a place to purchase these or is there a certain brand or model that they duplicate.( mot sure about bolt patterns and such ). Anyway I was thinking about putting a bigger sprocket on the back to give it mnore umph.
Old Jan 16, 2006 | 01:02 AM
submakr's Avatar
I ended up going with the 32T from http://www.kazuma.com/parts/index.asp. It was the largest they had. The bolt pattern is LT80 but the LT80 has either a 428 or 520 chain. The Kazuma has the 530. If you want to go larger than 32T you can get a late model LT80 520 sprocket and it will fit the 530 chain. The pitch is the same but the width is a little wider on the 530 chain but it will fit. This is going to be my next step!!
Remember that you will need to add links when you go bigger. I got my links from Lowes and the fit perfect.
The 32T I used did help the bottom end but not enough. I would have tried to go with a 35T but I was pushed for time so I had to settle with the 32T. We run sand paddle tires so we need all the bottom end we can get.
Good luck!!!
Old Jan 16, 2006 | 07:08 PM
conan2005's Avatar
Thanks for the info but who makes the LT 80? I was thinking Suzuki. Anyway, would it be better to put a bigger sprocket on the bak or smaller on front?
Old Jan 16, 2006 | 09:26 PM
submakr's Avatar
LT80 is Suzuki. I was unable to id a replacement front that was smaller than 12T. I put alot of effort into it. You are going to be pretty much limited to the rear!!
buddieboy
Dec 9, 2016 05:50 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
