Kazuma 110 chain and sprocket
I am sorry I do not know the answer to this question, but I will see what I can find out for you. Might take me a day or two or maybe someone else will post faster then me, the guys in this forum are great! most time they reply before I even get to them!
Mini ATV Raceway ATV
I figured out that the chain size is a an incredible 530!! I wonder why they used such a large size. That is normally for 1000cc plus motors. A 520 would have been perfect.
Im also looking to repalce the sprockets on my kids kazuma, did you ever find a place to purchase these or is there a certain brand or model that they duplicate.( mot sure about bolt patterns and such ). Anyway I was thinking about putting a bigger sprocket on the back to give it mnore umph.
I ended up going with the 32T from http://www.kazuma.com/parts/index.asp. It was the largest they had. The bolt pattern is LT80 but the LT80 has either a 428 or 520 chain. The Kazuma has the 530. If you want to go larger than 32T you can get a late model LT80 520 sprocket and it will fit the 530 chain. The pitch is the same but the width is a little wider on the 530 chain but it will fit. This is going to be my next step!!
Remember that you will need to add links when you go bigger. I got my links from Lowes and the fit perfect.
The 32T I used did help the bottom end but not enough. I would have tried to go with a 35T but I was pushed for time so I had to settle with the 32T. We run sand paddle tires so we need all the bottom end we can get.
Good luck!!!
Good luck!!!
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
