700 EFI problem
Old Dec 2, 2005 | 11:49 PM
67bullet's Avatar
Default 700 EFI problem
I have spark, compression, and 40 lbs of fuel pressure. BUT the bike won't start, everything was fine until one day the bike stalled and hasn't restarted since.
Check compression, the only thing I can come up with is the CDI box, not getting the spark at the right time....anyone else have any similiar problems?
Old Dec 3, 2005 | 12:03 AM
67bullet's Avatar
I see they have a "Coil" listed for parts, but NO CDI box, .......is the ignition timed inside the computer?
Old Dec 3, 2005 | 04:15 AM
Charlie's Avatar
You need to make sure you have voltage to your fuel injectors and that your spark plugs are good. Have you checked for any codes flashing when you turn the key on?
Old Dec 3, 2005 | 10:25 AM
67bullet's Avatar
Spark plugs are new, bike won't even try to start with starting fluid or carb cleaner.
I'm not sure how to check the codes on the new EFI bikes... Anyone know how?
Old Dec 3, 2005 | 10:53 AM
nfox's Avatar
Turn the key on and of three times and leave it on the third time and the check engine light will flash and it will say wait and show code numbers if any are present. My 04.5 700 efi died thursday night and now when i turn my key on i don't hear the fuel pump run and i have two codes 41 and 45, back to the dealership.
Old Dec 3, 2005 | 12:31 PM
67bullet's Avatar
I ran the codes.. how about a code 61..... Anyone have a list of the codes ?
Old Dec 3, 2005 | 12:40 PM
x_scrambler3's Avatar
Look in the owners manual an it tell you how to do the check right you have the code for end 61
Old Dec 3, 2005 | 01:19 PM
67bullet's Avatar
Anyone know what code 21 is?
Is there a list if the codes anywhere on the internet for the 700's?
Old Dec 3, 2005 | 01:30 PM
loss of synchronization is 21
Old Dec 3, 2005 | 01:51 PM
JCDEYO25's Avatar
Not sure if the codes are the same, but these are the codes for a 2005 700 EFI.......Code 21 is loss of synchronization.not exactly sure what that is.......code 61 will display after all codes have been transmitted........
John
