250 trailboss ping
Old Dec 4, 2005 | 05:21 PM
drlang's Avatar
Default 250 trailboss ping
Here's the dope, it's a 93 250 trailboss 4x4. The machine had a complete rebuild all the way down to the crank bearings before last winter. In the quest for more power I had the head milled, .020 during the summer and installed. At this point I had a ping on 87 octane. Started running 93 octane all was good. Got 4in. of snow last night, went out plowing and it seemed the ping came back on low rpm's. Under full throttle and more load I couldn't here the ping. It's got a k&n filter, one size over main jet, and the clutch spring has been replaced for higher engagement. Maybe it's just the load on low rpm's, and it can't be fixed.
Old Dec 4, 2005 | 06:21 PM
powerslider's Avatar
You risk piston damage riding it like that, with the colder temps your probably lean. go larger on the main jet and turn the airscrew in a turn and see what that does. You may also have to raise the needle to richen the mid range...
Old Dec 4, 2005 | 06:46 PM
2manytoys's Avatar
Yep it sounds like you are lean. Do a plug check at idle and midrange after it is warmed up. You should be brown color. If you are gray or white then you need to richen it up.
Old Dec 4, 2005 | 08:55 PM
drlang's Avatar
Thanks guys, had a notion about a lean condition. Needed some confirmation. That machine pushes a 5 ft. plow around really well, and being physically small I can get into alot of tight spots to plow.
Old Dec 5, 2005 | 12:04 AM
Budman650's Avatar
5 ft. plow? Something that big should be on the front of a Dodge diesel truck.
Old Dec 5, 2005 | 01:47 AM
IdahoVinnie's Avatar
5 feet = 60 inches
A 60" blade can be used on a 500cc or larger atv. My Vinson handles it quite well.
Old Dec 10, 2005 | 07:42 PM
drlang's Avatar
Upped the main jet from 150 to 160. Thanks guys
Doc
Old Dec 10, 2005 | 10:06 PM
atvdragracer's Avatar
not enough octane for the compression you have now, IMO.
68_327_c20
Nov 25, 2023 12:26 PM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
BIGFOOT
Feb 27, 2000 07:06 PM
BIGFOOT
Feb 14, 2000 10:29 AM
