How many hours needed?
Old Dec 4, 2005 | 11:51 PM
Fenton88's Avatar
Default How many hours needed?
I was just curious on how many hours is needed to make sure that everything is set after a .020 bore and wiseco piston is installed on a 250 trail blazer? we started it up and let it idle in the garage for around 2hrs and then have roade it maybe 3hrs..would that be enough for everything to set? cuz i don't wanna start pinnin the throttle and tear up the new rings and everything and have to go thur another rebuild..thanks in advance.
Old Dec 5, 2005 | 12:40 AM
x_scrambler3's Avatar
For a 2stroke it is not good to let ideal fro a long time. When you do a rebuild all you need to do is make about 4 or five pass back an forth at differnt rpm's an don't keep it an steady rpm an no wideopen till done. Did you run a richer mix of oil the first runs too.
MikeyBoyesq
Nov 27, 2020 02:44 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Jun 10, 2015 12:45 AM
Jun 3, 2015 01:40 PM
