banshee questions what do you call the 2 screws under the banshee seat? what are they for? how much adjust?
could you please explain those 2 screws under the banshee seat
when you adjust to the right as if you are pushing the throttle and if you turn them left the engine idles
thanks guys
thanks guys
if im thinking of the same ones you are, those two screws under the seat are the idle screws. they sit on top of the tors system boxes.
why would you adjust these idle screws- for what reason- what engine sound would be correct
What I usually do is adjust the idle down until it tries to sputter a little, then crank it up a bit. I idle up a little more on a 2 stroke than a 4 though.
