oil replacement on blaster....
Old Dec 5, 2005 | 07:10 PM
masterblaster123456's Avatar
Default oil replacement on blaster....
i got a 97 blaster and whenever i turn it on in nuetral...n start to pull the clutch it makes this wierd loud buzzing noise...n sometimes it just stalls....it sounds horrible...but once i get into like 2nd or 3rd gear which only happens sometimes its all good..im thinking it might be the oil...bc i dont have a back oil container above the left rear wheel...do i neeed that?....i know i put in the right 50 to 1 ratio with the gas n oil mixture for the 2 stroke...but is ther another oil compartment on the engine im not looking at...like a dipstick of some kind...please reply...thax....
Old Dec 5, 2005 | 11:00 PM
89warrior's Avatar
i dont really know much about 2 stroke engines but im pertty sure there is not any internal oil unless you have a wet clutch. the only oil should be mixed with your gas. I would think. sorry im not much help.
Old Dec 6, 2005 | 01:30 PM
04Warrior350's Avatar
i dont know too much about blasters either but my brothers blaster still has the oil resevoir on the back. blasters come stock with the oil resevoir so you dont have to mix oil and gas. you must have a block off kit. i dont know what the buzzing is from if you could describe where its coming from that would help. there is a internal oil system on these its for the tranny and gears. i dont know what type of oil you use in it though cause we havent changed my brothers yet. hope that helps a little . also the common mixture i know of is 32:1 for the gas y ou could try that.
Old Dec 6, 2005 | 01:33 PM
sorry i just reread your post and it could be the tranny fluid since it happens when you pulll the clutch. im not sure though. might call a dealer and ask them about it
Old Dec 6, 2005 | 02:19 PM
yeah i think i might just let the dealer take care of it....i dont wanna screw it up anymore...thax guys...
toonces
Aug 5, 2015 05:55 PM
U2OFlyer
Aug 5, 2015 12:46 PM
toonces
Jul 28, 2015 01:58 PM
trouttracker
Jul 20, 2015 11:54 AM
jettman
Jul 6, 2015 12:16 PM
