Fuel pump ?
Old Dec 5, 2005 | 10:44 PM
HUND's Avatar
Default Fuel pump ?
I have a 1987 four trax 350 4x4
The fuel pump went out and need a replacement.
Can anyone help me out .... Thanks , Ron
Old Dec 6, 2005 | 05:08 PM
4Run4Fun's Avatar
Default Fuel pump ?
May be wrong, but I thought it was gravity feed. - no pump
Old Dec 7, 2005 | 12:16 AM
HUND's Avatar
Default Fuel pump ?
No It's a electric pump. I pulled off the gas filter tonight and tried to get gas to drain from the tank.
Is the tank pressurized from the pump to keep it primed ? With the gas valve open it won't drain ???
I'm stumped , I found a pump at a local dealer for $135
It buzzes just after I stop turning the motor over for 2-3 seconds ...
Help ! before I throw down the $$$ for the pump
I need this quad going asap ... It's duck season !!
Old Dec 7, 2005 | 08:53 AM
dzzy's Avatar
Default Fuel pump ?
No the fuel tank is not pressurized, matter of fact there's a vent on the gas cap...make sure it's open to atmosphere. Fuel will not necessarily just run out of line, I think it would depend on how much fuel is in the tank. A small suction from the pump should be enough to quickly fill the lines and carb though. The electrical would seem good (fuel pump buzzing after engine turning over). A rapid buzzing indicates no fuel to pump...sounds like something wrong the tank...look inside...is there gas? Is it rusty?
PrairieDog126
Sep 12, 2015 06:53 PM
essonlaker
Sep 10, 2015 01:12 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Elkaholic
Sep 6, 2015 02:44 PM
