04.5 500 HO needle adjustment question
Old Dec 8, 2005 | 08:43 PM
simonsez's Avatar
Default 04.5 500 HO needle adjustment question
Hello, in the winter do i move the needle valve clip up to make it richer or down to make it richer? If i remember correctly it is moved down to bring the needle up higher to allow more gas. Is this the correct way? Thanks in advance for the help.
Kevin
Old Dec 8, 2005 | 08:47 PM
SPORTSMAN70003's Avatar
Yes you move the clip down to make it richer.
Old Dec 8, 2005 | 09:23 PM
simonsez's Avatar
Thanks for the confirmation, i couln't remember from last year.
Old Dec 8, 2005 | 09:27 PM
Your welcome. I've played with my carb so much I could probably rejet it in my sleep lol.
Old Dec 9, 2005 | 12:31 PM
Deerkiller's Avatar
I too haven't adjusted the carb on my SP500for winter,
Mine seems to run ok with the stock needle settings, idles a little low i guess,but it's not really to cold yet, 18 above this morning. What symptoms should i be looking for? how many positions should i change?
If someone has written a proccedure for changeing the clip location could you lead me to it.
Thanks
Old Dec 9, 2005 | 01:43 PM
You should do a plug check to see how its running and then you could see if you need to rejet. Most of the sportsman's come jetted a little rich.
Old Dec 9, 2005 | 01:52 PM
Deerkiller's Avatar
Thanks, I'll check it after runneing in the cold awhile. If the idle is the only thing going on i can adjust that easy enough i'm sure.
So do they typically need to be leaned or richened in the cold?
Old Dec 9, 2005 | 01:55 PM
They need to be a little bit richer.
Old Dec 9, 2005 | 01:58 PM
Deerkiller's Avatar
Thanks again, big help.
Old Dec 9, 2005 | 02:04 PM
Deerkiller's Avatar
Is your front winch mount from Polaris or the winch manufacturer. Looks strong and appears to mount the fairlead right on it.
