Shiming front springs
Old Dec 8, 2005 | 09:48 PM
gary500HO4x4's Avatar
Default Shiming front springs
Hi all. I am new to this and wondering if anyone can help me. I have a 05 500 HO 4x4. I really like it. The problem is the springs are starting to loosen up. I was trying to put a shim under the spring and in the process it looks like the front axle came apart inside the axle boot. Anyone have ideas on this? did I break the joint?
Old Dec 9, 2005 | 09:03 AM
kj330's Avatar
you didnt break the joint. you just pulled the hub of the locking ring on the axle shaft. if you remove the large spring on the axle boot and pull the boot back the hub will come right off in your hands. just line up the splines and hit it with a rubber mallet to seat it.then reinstall your strut.
Old Dec 10, 2005 | 02:03 PM
thank you so much for your help. I will certainly try that. thanks again.
ghost civic
Jan 15, 2020 07:43 AM
carolinabomb
Jul 26, 2015 08:40 AM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
