Kodiak Skip
Old Dec 9, 2005 | 03:46 PM
kodiaktracker's Avatar
Default Kodiak Skip
Hello All...Got a problem, I went out to plow the driveway after the 8" snowfall we just had with my kodiak 450. After about an hour, the kodaik developed a engine miss, but only when I was in reverse. Just to let everyone know the differential was not locked in and it didn't skip when going forward. I thought it may have been bad gas, but it seems odd that it would only miss backing up. Any ideas
Old Dec 9, 2005 | 03:48 PM
WindmillAtWork's Avatar
Default Kodiak Skip
Yup ran into that myself. Its a safety feature so you don't go that fast in reverse. It also does that when you lock the differential. You can overide that one by hitting the overide button if you must go faster. Don't think that works in reverse but might. Give that a try.
Old Dec 9, 2005 | 07:04 PM
hondabuster's Avatar
Default Kodiak Skip
The override button only works on diff lock, for reverse youll need to wire up a bypass switch.
Depending on the year of your kodiak, the info for the grizz works, same wire color and location. Check out this site for instructions.
grizzhopper
Old Dec 9, 2005 | 11:37 PM
kodiak48's Avatar
Default Kodiak Skip
i would like to know if this mod works on the kodiak
Old Dec 10, 2005 | 01:27 AM
Default Kodiak Skip
Yep, works on the bruin too. Same wire...green with white stripe.
Old Dec 10, 2005 | 08:18 AM
Default Kodiak Skip
Thanks...great information [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 10, 2005 | 08:35 AM
Default Kodiak Skip
Thanks for all the info. I will be trying that today. Looks easy enough. Thanks again
MeadowlarkFarm
Nov 27, 2019 08:40 PM
YankeeRebel
Oct 6, 2015 06:44 AM
Minimod
Sep 10, 2015 08:03 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
black_thunder
Sep 6, 2015 04:41 PM
