500 Scrammy 4wd problem w/ hilliard clutch
Old Dec 11, 2005 | 10:45 AM
creepr91's Avatar
Default 500 Scrammy 4wd problem w/ hilliard clutch
Ok, I am having a problem where my left front wheel will not lock into 4wd
It was working fine, then I changed a cv boot and now It wont work. I understand the general principle of the clutches operation. And I have done the following.
1. Checked Voltage to wires to hub
12V at hub
2. While the switch is on the armature plate sticks fast to the magnet
3. The clutch mechanism appears to be working and moving freely
At this point I am wondering
1. Do I buy a new armature plate? Is there a thickness test
2. Weak magnet?
3. Worn Hub? Any way to test
Remember this was working fine prior to cv boot replacement.
Old Dec 11, 2005 | 12:08 PM
ftwflh's Avatar
What did you torque the hub nut to?It needs to be 18-20 ft lbs and tighten it while spinning the wheel.
Old Dec 11, 2005 | 12:24 PM
creepr91's Avatar
I took everything from the side that is not working swapped to other side.
The problem follows the strut. I think its the mag coil, there is magnetism, but the left side definetly has less pull.
How do you get that magnetic coil out of the hub? It looks like that seal section must come out first.
skinnyr6
Aug 25, 2023 02:18 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
cornermike
Jul 8, 2015 11:44 PM
honda71
Jul 8, 2015 02:13 AM
