EX or Z
Old Dec 11, 2005 | 07:11 PM
04trx250ex's Avatar
Default EX or Z
ok 400ex or z400, which one of these quads is better for rutted dificult trails? which one is better for steep hill climbs? and which is a better duner?
Old Dec 11, 2005 | 07:55 PM
trailntrack's Avatar
Default EX or Z
Well i would much rather ride the z...the z has reverse and i have rode one, and it climbs excellent! compared to a 400ex, which is too light in the front end, so i would definitly pick the Z400
Old Dec 11, 2005 | 08:15 PM
04trx250ex's Avatar
Default EX or Z
im talkin about the 06 models, so both have reverse, i also hear that the z you have to shift more often, and that the ex has better low end but the has better top ene,
Old Dec 11, 2005 | 08:16 PM
04trx250ex's Avatar
Default EX or Z
but the z has better top end*
Old Dec 11, 2005 | 10:29 PM
midnite's Avatar
Default EX or Z
Ihe z is the better machine in every posible way.
Old Dec 11, 2005 | 11:22 PM
RIDER11X's Avatar
Default EX or Z
Unless you really like changing out timing chains I'd stay away from the Z, as they eat them up. The 400ex bone stock has a little less top speed and that is about it. The 400ex will grunt it's way through tough trails without stalling a bit easier than the Z as well. When the YFZ's came out, I ran Harescrambles on my 400ex and did very well. Riding something you like is very important, as well as it must not let you down either. I trust a Honda over anything else.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 12, 2005 | 02:11 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default EX or Z
The EX is by far the better machine for semi-technical trails where you have to ride slowly. It has an engine that doesn't mind being lugged down. Just put it is 1st gear and idle on through.
The Z has an engine that likes to be ridden revved out (but not as much as say a 450R) and it has a lighter flywheel, so it isn't a happy at really slow speeds. If you are going to go slow, you will need to do lots of clutch work.
The Z with just some simple mods like opening up the airbox and a pipe, has way more motor than the EX. This makes it a better choice for the dunes and anywhere you need lots of top end speed.
When I am going on a trail ride, I pick the EX. For open faster trails and mixed desert, I pick the Z. For the wide open desert, the 450R is my chariot of choice!
Old Dec 15, 2005 | 10:28 AM
backtrailboy2332's Avatar
Default EX or Z
"reconranger"
thats so not true. my kfx does not mind low speed at all. it is a champ through technicals too. i will say that the 400 ex is the cadillac of quads but the kfx/z is cheaper and faster. as for clutch work, first gear will crawl without playin wit the clutch at all. the z/kfx has good bottom end too.
Old Dec 15, 2005 | 10:48 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Default EX or Z
This statement is completely false! I owned a Z400 and never had a problem, my friend's Z has MANY hard hours on it and it runs flawless.
The EX will lug down a little better making it better on technical trails, and the Z is a little more peppy and smoother making it a little more better everywhere else. Either way they are both bullit proof and will get you where you need to go.
Old Dec 15, 2005 | 12:16 PM
RIDER11X's Avatar
Default EX or Z
Really? Let me enlighten you and others with this Link about z400 timing chain problems.
[img]i/expressions/face-icon-small-wink.gif[/img] It's always good to do your research.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
