kodiak power in reverse
Old Nov 2, 2000 | 12:40 PM
mpbspb's Avatar
The other day I hooked up my winch to a friend of mine who was stuck and tried to pull him out in reverse. The motor bogged down and would not even spin the tires. Is this normal or am I doing somthing wrong?
Old Nov 2, 2000 | 01:23 PM
FKNA's Avatar
I hope like hell it's normal because I have the same problem with mine and just "assumed" it was normal.
Old Nov 2, 2000 | 02:14 PM
bowtiepu's Avatar
not sure if its normal but using your winch like that is not normal and will definitely ruin it..its not made to be used like that,just thought id let you know
Old Nov 2, 2000 | 02:23 PM
mpbspb's Avatar
Its not just when I have my winch hooked up it happens sometimes when i am in think mud. I think the bike is just underpowered in reverse
Old Nov 2, 2000 | 02:52 PM
Ozark's Avatar
The Kodiak has a rev limiter that limits speed while in reverse. This is a safety feature to help prevent out of control accidents while in reverse. I am not a big fan of this, and some dealers can install an over ride.
Ditto on not using the winch as a tow strap this is very hard on the cable.
Old Nov 2, 2000 | 03:47 PM
FKNA's Avatar
Thanks for the info Ozark.....I'll have to find a way to disable that limiter
Old Nov 3, 2000 | 11:17 AM
monk01's Avatar
Just look at any Polaris and you can find out how to do it. They all have an overide for the reverse rev limiter. I have experienced the same thing with my Kodiak.
Old Nov 3, 2000 | 01:27 PM
FKNA's Avatar
Monk, what did you do to override the limiter on the Kodiak?
Old Nov 3, 2000 | 02:22 PM
mpbspb's Avatar
The rev limiter overide will help when you are spinning the tires, but the problem with my kodiak is the lack of power to even get them spinning. I think the reverse gear is not powerful enough. In low foward gear there is plenty of power but not in reverse.
Old Nov 3, 2000 | 11:59 PM
Roar's Avatar
True story, the reverse is just to high geared. What is really bad is when you get your backside in a bind and have no way to safely back down and out of trouble.
