warrior, sucking through exhaust
Old Dec 12, 2005 | 01:01 AM
flyboeing's Avatar
Default warrior, sucking through exhaust
So I am out at Gordons well this weeekend riding my buddies 97 warroir 350, coming down the hill to camp it starts cutting out, no problem figure it got loaded up, let off it get back on runs great. Later that night barely get out of camp go up one small(real small) hill, it stalls and won't start. It spins the motor like there is no compression, feel on the exhaust and there is a sucking and blowing with the piston. Ok so the cam chain broke and the exhaust valve is stuck open, get towed back to camp and pull the inspection cover and the chain is fine and still turning.
Without tearing down the motor, any ideas? I am thinking maybe it skipped a couple of teeth and the timing is off, maybe the cam sheared inside of the gear?
Is the warrior an interfearance motor, are the valves bent. Seems real strange as it was running so good right before it died.
Thanks in advance, I hate when I brake other people's bikes!
Old Dec 15, 2005 | 01:36 AM
flyboeing's Avatar
no ideas?
Old Dec 15, 2005 | 02:45 AM
IdahoVinnie's Avatar
If it's sucking and blowing through the exhaust, then you KNOW that there is an internal problem. Bite the bullet and tear it down. Sorry...
Old Dec 15, 2005 | 11:46 AM
Kodiak660's Avatar
You could have a stuck valve
Valves could need adjustment
Or you could have burnt an exhaust valve.
Cure might be to adjust your valves then run a compression test on it.
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
