tranny vent line on HO
Old Nov 2, 2000 | 01:05 PM
silverado's Avatar
i was lookin my HO over this morning to see if the vent lines was all in place and noticed that they run up to the pod. my 99 ran into the frame.is this new for 01??
Old Nov 2, 2000 | 02:51 PM
gregsims's Avatar
My 2000SP500 tranny vent line went into the dry/box. I rerouted it into the airbox.
Greg
Old Nov 4, 2000 | 11:53 AM
MNXPLORER's Avatar
silverado, Polaris is learning! Thats where all your vent lines should go. Guess you won't have to take the time to do it yourself. Remember to vent the radiator overflow up high also if you plan on swamping with your new ride!
Old Nov 5, 2000 | 03:42 PM
silverado's Avatar
whats the best way to vent the coolant bottle cap???
Old Nov 6, 2000 | 10:24 AM
MNXPLORER's Avatar
silverado, I'm not sure of the best way but, here is what I did. I modified a grease zerk fitting by drilling out the center. Next I drilled out the small vent hole in the cap to the right size and threaded the fitting into the cap. I then found the right size line at the hardware store. I routed the line up to the frame rail and up into the headlight pod. I tucked the end several inches down the steering stem, so if it ever overheated the boil over wouldn't hurt anything. The only problem I had was keeping the line on the fitting I solved this by wiring the hose to the fitting. Hope this helps.
Old Nov 6, 2000 | 10:36 AM
silverado's Avatar
yep i might try that spound good to me.has anyone eles done anything differant?
Old Nov 6, 2000 | 01:59 PM
bowtiepu's Avatar
basically thats how its done except,you can buy a brass fitting that is ribbed and made to accept rubbuer/clear tubing,that way you dont have to worry about it falling off and you wont have to zip tie it
Old Nov 7, 2000 | 10:31 PM
screamin4wheeler's Avatar
I put a ice maker's compression fitting and drilled it into the cap and then ran the line up to the pod. The compression fitting holds onto the line good and the fitting has threads on the other side to seal the cap. Worked great and took about 10 minutes to do. Any hardware store carries these.
Rick
ReconBayou
Oct 31, 2022 05:37 PM
Mar 21, 2016 06:30 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Logan Collins
Sep 5, 2015 08:03 PM
