Winch Cable
Old Nov 2, 2000 | 05:14 PM
MaoZ's Avatar
I am trying to replace my winch line on my Superwinch but I can't seem to find cable with a strong enough work load. The highest work load I can find is 850lb. Can someone tell me where I could find aircraft cable or a suitable super strong cable? I have no idea where to look for such an item. Is 50ft of 3/16" cable about the maximum you can fit on a Superwinch wheel? Thanks for the information.
Old Nov 2, 2000 | 08:32 PM
Tree Farmer's Avatar
J.C. Whitney catalogs winch cable; look up "Wire Rope" in the yellow pages of your telephone directory for local sources.
You can cram more cable on a Superwinch spool, but you lose extraction force from the leverage of the radius of a too-full hub.
Tree Farmer
Old Nov 2, 2000 | 10:00 PM
TxDoc2's Avatar
About $20 from www.northentool.com or Tractor Supply.
Old Nov 6, 2000 | 04:00 AM
rancher's Avatar
about 40 to 45 feet is all you can get on a superwinch 1500. i have one on my rancher, got it at the farm store, 3/16 cable and the hook and fittings cost about $16.
rancher
Old Nov 6, 2000 | 12:57 PM
DeadEye's Avatar
go ahead and get 1/4" cable the only mod your have to make is to slightly drill out the hole in the spool.
00' rancher 4x2 es, 26x12" mudrunners on the rear, 1500lb winch w/ 50ft of 1/4 in.cable, herculined rack.
Old Nov 6, 2000 | 03:35 PM
MaoZ's Avatar
I found 3/16 cable at Home Depot, Lowe's, and a couple of other hardware stores but the workload limit is 850 pounds. I hope you realize that. The cheapest I can find 3/16 aircraft cable is Tractor Supply. 49 cents per foot of 3/16 galvanized aircraft cable. If my information is correct its workload is 3700 pounds, as compared to the cheaper 850lb cable. I got the crimping tool for $22 but I am going to return it after I use it. Does anyone know how many feet of cable I could realistically put on the spool? 60-65 feet? I would get the 1/4" cable but it is way too expensive and I can't see needing the extra diameter. Any thoughts to the contrary would be appreciated - Deadeye being one for sure. Thanks again for the information!
Old Nov 7, 2000 | 02:04 PM
DeadEye's Avatar
It's sounds like the question is the price... It was a major factor when I replaced my cable as well. I checked everywhere (home depot, lowes, TSC...etc) and if you buy it by the foot they will really burn you, but I found at home depot (right above the spools)a box of precut wire that already had the crimping and hook attatched for about 1/3 the price. hope that helps.
Johnny Mac
Aug 15, 2019 03:13 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
chewy78
Sep 8, 2015 10:37 AM
