20hr service
Old Dec 14, 2005 | 10:53 AM
4Run4Fun's Avatar
Default 20hr service
Its time for the 20hr service on my new Rancher and Recon. Should I let the dealer handle this? How much can I expect to pay?
Old Dec 14, 2005 | 11:39 AM
ford8n47's Avatar
I just did mine on my new 05 Rubicon ES. I changed the oil and filter and that was it. Cost for that stuff was $37 bucks. I bought the oil and filter at the dealer. If you can change your oil in your truck or whatever you can do this. I would recommend a torque wrench for the bolts if you do not know how to "feel" the recommended pounds. I did not have the valves inspected because I don't think it really needs it. And just check the rest of the ATV yourself. It is your bike you should get to know it. Hope that helps. Oh ....just call the dealer and ask what they charge for the 20hr svc. Should be around 100 bucks.
Old Dec 14, 2005 | 12:16 PM
Green05Giant's Avatar
i did the same as ford8n47, i just changed all that my self ...i know my dealership charges $130 per wheeler! and i have two 05 foremans... saved a bunch of money doing it my self!!!thats basically what there going to do is change your oil and filter ...they will check more fluids and tighten bolts make sure everything is still workin but surely you can tell if your brakes and stuff like that is workin!!!!
Old Dec 14, 2005 | 12:25 PM
4Run4Fun's Avatar
So basically, that valve adjustment they are saying is crucial is not really all that important after 20 hours?
Old Dec 14, 2005 | 12:37 PM
both of mine still run just fine and iv got almost 200 hrs on them not a problem yet...and of course there going to tell you that something has to be ajusted to get your money but like i said man if you dont feel comfortable then have the honda shop do the service.
Old Dec 14, 2005 | 05:07 PM
quicksilver's Avatar
the valve adjustment is important so you dont toast your valves or wear the valve train out. Pretty easy to do, just takes about a half hour or so, the service manual tells how to do it. I checked mine on my '05 at 20 hrs, they were perfectly fine, didnt have to adjust anything. But it depends on who put it together at the factory, they could have been tight or loose, it's just a good idea to check it at least once every couple years or if they get noisy.
Old Dec 15, 2005 | 12:39 PM
action450s's Avatar
Every time I've come accross this, I always say the same. Have the dealer do the first service.
This'll gurantee your warranty if something happens and they question if maintenance was done
It lets a trained person adjust the valves which is the life of a 4 stroke motor
A good shop adjusts all the cables, brakes and checks all nuts and bolts. This is the stuff that wears in after the first 20 hours and usually dont have to be touched again for a long while or at all.
After this service I do all my own maintenance, as many of the services performed after 20 hours rarely need to be looked at again.
Basically a 20h service should be much much more then a simple oil change.
Customer Service #1
May 15, 2020 08:46 AM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Elkaholic
Sep 6, 2015 02:44 PM
