600cc twin 2 stroke exterminator
hsp will release a high performance race ready quad with engines ranging from 440 to 700cc twin 2-stroke variable exhaust on 440,500,600cc.hp will be about 130 on the 600cc engine.gas shocks remote reservoirs with more than 11 inches of travel suspension rear and front.aftermarket chromoly hsp chassis.the only polaris parts on those quads will be the stock plastic.they plan to built 25 to 50 per year.the price is still in the air because of the options customers will have.
I may not know much about quads, but I do know something about sleds. If these quads are based on Polaris sled engines, the 600 would not make anywhere near 130hp. You have to remember, there is a huge difference in the state of tune, when you run at an average temp. of 15 to 20 degrees F. A two stroke makes alot more power at low temps, as does any other motor for that matter, because the air contains more oxygen per volume, the colder it gets. Bottom line, the 600cc twin in a snowmobile only makes around 110hp. By the way, how are they going to cool this beast? Ever see the heat exchangers on a sled? No room for enough cooling on a quad chassis. A two stroke generates a tremendous amount of heat when you start to produce the kind of power per cc that snowmobile engines produce.
keep dreamin there will never be a new 2 stroke built. just look at what they did at glamis. they are going to ban 2 strokes all together. they just cam out with an 1100 4 stroke snowmobile and next year honda will release a 4 stroke wave runner.
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sw00p
Sep 24, 2015 02:50 PM
