Just got a new 2006 DVX 400...looking for advice
Old Dec 18, 2005 | 12:46 AM
crazymfer's Avatar
Default Just got a new 2006 DVX 400...looking for advice
I would like to get some aftermarket parts and i was wondering if the 2006 Z400 parts would fit fine on a 06 DVX.
Old Dec 18, 2005 | 03:45 AM
Bear4570's Avatar
The 2 bikes motors and frames are identical along with the KFX400 also. The plastic is different only.
Old Dec 18, 2005 | 09:39 AM
crazymfer's Avatar
hey buddy, thanks a lot, i thought they might have been the same because everywhere i look and read about it, everything always says that they are the same machine but different plastic, but i wasn't sure about the 2006 model, but thanks for your time
Old Dec 18, 2005 | 10:30 AM
VegasPredator's Avatar
Pipe.... jetting.....air filter to start big big difference in performance...good dependable quad.......good luck !
Old Dec 18, 2005 | 07:07 PM
crazymfer's Avatar
Thanks for your help, but what kind of pipe would you recommemend? A slip on or a full exhaust pipe, and what name brand would be the best for the DVX. Looking for great sound and performance
Old Dec 19, 2005 | 06:39 PM
RaptorRidr660R's Avatar
On of the best pipe for the suzuki motor would be the Yosh! They helped design the original 400 that the Z motor is based on!
Old Jan 2, 2006 | 11:54 PM
RODDYFZ450's Avatar
My wife rides a 2004 DVX400, we put a Trinity Racing full pipe and jetted it. The thing screams, maybe not quite as much as my YFZ450.
Old Jan 3, 2006 | 05:45 PM
Redcruiser500AC's Avatar
Crazymfer, congrats on your quad, I had a 06 DVX and only had it a few months and sold it, One MAJOR chunk of advice is to drain the stock coolant and put in Evans Waterless coolant, there is a big problem with the 05 and 06 Suzuki engines and that bleeds over to the DVX and that is the Magnesium engine covers the coolant is having a Cemical reaction with the covers and corroding them really badly after only a few months, mine was built in september and it was corroded badly, it is the cover on the water pump side the cluch cover, if it gets bad enough it will corrode through and dump coolant in the engine majorly so far there is no recall from Suzuki, Arctic Cat, Kawasaki. You can go to evans websight and they have a dealer locator you only need like 2-3 quarts but it only comes in a gallon and that will do. But a gallon is like $27.00 and you though gas was high, Hope this helps. Doug
Old Jan 4, 2006 | 04:26 PM
jaxxdog's Avatar
Hey, just enjoy it, you bought a nice quad.
Old Jan 29, 2006 | 11:03 PM
FOURTEEN's Avatar
The 2006 Suzuki brochure says: "37mm carburetor".
The 2006 DVX 400 brpchure says: "36mm carb"!!
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
