Sag in the front of my SP800
Old Dec 18, 2005 | 09:20 PM
Nolesfan's Avatar
Default Sag in the front of my SP800
I have a 52" glacier plow on the front of my SP800 and even when the plow is on the ground(no weight on the suspension), the front tires angle in. I'm not sure if I just never noticed this or do I need spacers? Is it set up this way or do I need to adjust the camber? What gives?
Old Dec 18, 2005 | 09:26 PM
JCDEYO25's Avatar
Nolesfan..
My 05 700 EFI is the same way..........I believe their set that way from the factory for better handling......
Old Dec 18, 2005 | 09:43 PM
tyler711's Avatar
I noticed the inward tires as well.
If you want to hold the plow better, you could always get MV or Ranger front springs and install them.
Old Dec 18, 2005 | 10:35 PM
spyder6's Avatar
all polaris Sportsmans come from the factory with Negative camber for better stability, turning and handleing
Old Dec 18, 2005 | 10:45 PM
JjEjFjf's Avatar
I just bought an 800LE yesterday and its the same way.
Old Dec 18, 2005 | 11:31 PM
Polaris500HO4x4's Avatar
Yes the sportsman has a 5 degree Negative Camber off set making up for the weight, this is normal and you will notice it more when the suspension sags down
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
