Scrambler 500 Throttle Adjustment
Old Dec 20, 2005 | 10:34 PM
hazmat01's Avatar
Default Scrambler 500 Throttle Adjustment
Is there a way to adjust the throttle on my Scrambler. When it idles you have to keep your thumb just barely on the throttle or it dies. And when I say just barely, it doesn't even look like the throttle moves when you let go. The engine speed doesn't even seem like it changes that much, but it must be just enough. When I first start it up and have the choke on it runs fine, but then I will take it for a ride and warm it up with the choke off and as soon as I let go of the throttle it shuts off. No matter how warm it is.
Old Dec 20, 2005 | 11:08 PM
bongload's Avatar
Did you ever try to turn up the idle?? Just wondering.
Old Dec 20, 2005 | 11:19 PM
ftwflh's Avatar
The adjuster is on the cable by the housing.It is a long black nut with a jam nut.Pull the rubber cover back and you will see how to adjust it.
Old Dec 21, 2005 | 05:40 PM
qdawg76's Avatar
Exactly What he said, I had the same problem with my sportsman and found this out the hard way
Old Dec 22, 2005 | 04:13 PM
hazmat01's Avatar
Thank you, I finally received the book for the ATV today. I appreciate the help.
scram5050
Aug 30, 2024 01:39 PM
ghost civic
Jul 30, 2015 04:09 PM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
maxjung
Jul 13, 2015 05:11 PM
MNatv89
Jul 7, 2015 11:36 AM
