250r getting no spark, please help!!
Old Dec 29, 2005 | 08:36 PM
RideOrDie420's Avatar
Default 250r getting no spark, please help!!
Well heres the deal.....i got a 89 250r, i bought it last year and it ran like a raped ape.....never had a problem with it until one day it just shut off while riding......after that i tore the whole quad down and redid the whole thing, sent the motor out to Eric Gorr for bottom and top end......got the motor back but no spark, bought a new CDI, stator, kill switch, and now finally a whole new wiring harness....Im pretty good at turning wrenches and have gone through all the basic things, done everything in the Clymer manual, but still no spark.....Getting Ohm readings from everything but still no spark.....This problem has got me stumped, the whole electrical is basically brand new. Please any input or help
Old Dec 31, 2005 | 03:09 AM
Daniel631's Avatar
You should check the voltage output of the stator and pulse coil. Make sure the kill switch isn't grounded.
Old Jan 6, 2006 | 02:54 PM
Morewood's Avatar
I assume you replaced the spark plug wire AND cap??
Old Jan 6, 2006 | 04:01 PM
pimpt250r's Avatar
wire and cap! what cap are you talkin about? i would change the wire and coil ,,, the 250r's are notorious for a weak spark theres a guy on ebay selling high output coils you should check that---- that is the most common flaw on the trx is a weak spark by the way what did you pay to have your bottom end done ,,,,good luck w/that you will figure it out-- it is 1 of the easiest quads ever to work on
Old Jan 6, 2006 | 05:10 PM
Morewood's Avatar
I meant the spark plug cap. I had one go bad on the Banshee, but not on the 88 nor 89 250R.
Again I assume you have changed all that stuff if you replaced the entire harness. Also, I assume you have tried at least TWO new sparkplugs....depending on where you are checking for spark.
Old Jan 6, 2006 | 08:10 PM
pimpt250r's Avatar
it says you own a lt500, you should take the coil off that for a quick check! i am almost positive there the same
Old Jan 6, 2006 | 08:27 PM
SMASHED's Avatar
take a break .....clear your mind.....and think about what your doing and don't foget the basics if all else fails go see the boys at OCC....JUST KIDDING just think and you'll fix it......
Old Jan 10, 2006 | 10:27 PM
dragracer789's Avatar
Both my R's coil went bad. That should of been the first thing you did. Replace it, and make sure the plug cap is screwed onto the coil wire good and snug.
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
