blaster motor swaps... need input
i want to get rid of the stock 200 and put in somethin that will be at least around 30hp. what dirtbike motors/atv motors would be worth putting in. i have seen people put in 250r motors but i dont have the ability to cut streatch, and reweld a frame. what motors would be more of a direct/somewhat direct bolt in. i coudl cut and move mounts around, just not mess with the frame. im lookin to do this and have it done by spring... thanks jeff
you might want to consider just trading the blaster in on something faster. With the short wheelbase and 30+ hp you'll probably have a hard time keeping the front wheels on the ground. If you really like your blaster and you're hellbent on doing a swap, just keep in mind that you might need an extended swingarm to keep it under control.
Elkaholic
Sep 6, 2015 02:44 PM
