blaster motor swaps... need input
Old Dec 30, 2005 | 12:46 PM
fastblaster00's Avatar
Default blaster motor swaps... need input
i want to get rid of the stock 200 and put in somethin that will be at least around 30hp. what dirtbike motors/atv motors would be worth putting in. i have seen people put in 250r motors but i dont have the ability to cut streatch, and reweld a frame. what motors would be more of a direct/somewhat direct bolt in. i coudl cut and move mounts around, just not mess with the frame. im lookin to do this and have it done by spring... thanks jeff
Old Jan 28, 2006 | 11:39 PM
Mitchelllesbirel's Avatar
I have headr that 1978-1985 YZ400 motors are fairly simple task to put in. If you want more info i can communicate with the person and let you know
Old Jan 29, 2006 | 12:07 AM
recon99's Avatar
you might want to consider just trading the blaster in on something faster. With the short wheelbase and 30+ hp you'll probably have a hard time keeping the front wheels on the ground. If you really like your blaster and you're hellbent on doing a swap, just keep in mind that you might need an extended swingarm to keep it under control.
Old Jan 29, 2006 | 02:21 AM
TheTurtle's Avatar
build the 200. 40+ isnt super hard to achieve, and as compared to doing a swap it will be a ton easier and not much if any more expensive.
2quiker
Mar 22, 2022 08:36 PM
fd24
Jan 16, 2019 08:59 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Elkaholic
Sep 6, 2015 02:44 PM
quickwhips
Sep 2, 2015 06:53 AM
