trx200sx electric start doesn't work
Old Dec 30, 2005 | 03:22 PM
twoodward15's Avatar
Default trx200sx electric start doesn't work
I have a good battery and used my multimeter to test it as well as hooked up a charger for testing. I have power into the solenoid (or what I believe is the solenoid, in with all of the other wires and the only fuse). I don't have power coming out the other side of it though. Should I have power there or not until the starter button is pushed? I got the quad 3 weeks ago. It needed some work, but the e-start worked the day I bought it. If it means anything, I do have power to the headlight and the kill switch works.
Old Dec 31, 2005 | 03:05 AM
Daniel631's Avatar
You should hear a "click" sound from the solenoid when you push the start button. You should get battery voltage to the starter side of the solenoid when you hit the start button.
Old Dec 31, 2005 | 10:27 AM
Ahhhh, thanks Daniel!!! I can't remember if I checked for power with the buttonb pushed but there is no click.
Old Dec 31, 2005 | 10:32 AM
Daniel, you wouldn't be able to tell me how to adjust the clutch would you? I know where the screw and nut are, just not the sequence of events. thanks!
Old Dec 31, 2005 | 12:36 PM
Daniel631's Avatar
Loosen the lock nut. Turn the screw in(clockwise) untill you feel light resistance, then back it out 1/4 to 1/2 a turn. Tighten the lock nut.
Old Dec 31, 2005 | 12:48 PM
thanks. I really appreciate it!
4xrider
Apr 10, 2017 01:36 PM
txkevin
Sep 21, 2015 02:02 PM
momofo
May 27, 2015 12:06 PM
rmx251
Sep 10, 2000 11:40 PM
mrdci
Feb 7, 2000 07:16 PM
