400 EX pinging
Old Dec 31, 2005 | 07:56 PM
kb3's Avatar
kb3
Default 400 EX pinging
My brother-in-law recently had a 440 kit installed in his 2000 400EX. While riding it yesterday it began to ping pretty loudly and is down quite a bit on power. We had recently rejetted the carb, if that is any help. I am going to be tearing into it next week but would appreciate any thoughts on where I should begin my venture. Carb? Head? Valve Train?
Ken
Old Jan 1, 2006 | 03:15 PM
Daniel631's Avatar
"pinging" to me means detonation. Running a higher octane gas will clean that up. If you are going to tear into the motor do a compression test first. If the compression is low you know you need to pull the head.
Old Jan 1, 2006 | 04:45 PM
450r's Avatar
what compression piston is it? what octane and brand of fuel? what jetting changes did you make and what is your carb set-up?
Old Jan 1, 2006 | 05:30 PM
kb3's Avatar
kb3
I did not do the origial work on the motor so I am not sure about the details on the 440 kit. I did change the main, pilot and needle. I dont recall what size, but it ran well for several days on 91 octane gas before the problem occurred. I have not ridden it so I cannot testify to the actual "pinging" sound but I have heard that 440's have a tendancy to stretch the head bolts and blow head gaskets, so that is where I was going to look first. Not knowing the proper compression ratio, it may be hard to determine anything from a compression test. Thanks for the responses so far.
Ken
Old Jan 1, 2006 | 05:45 PM
1988fast250x's Avatar
TIMING CHAIN~~ i had the same problem! get a new one!! before you bend the valves and screw up your piston! i messed up the piston on my bike! sux but oh well! well i hope this helped
Old Jan 1, 2006 | 05:46 PM
450r's Avatar
perhaps a little more research before tearing it down will answer some of this.
Old Jan 1, 2006 | 05:54 PM
honda400rider's Avatar
Running a 440 might require race gas or the use of octane booster to 91 octane fuel.
candoo
Dec 4, 2003 06:43 PM
tater0519
Apr 21, 2003 10:59 AM
jt
Mar 10, 2003 02:26 PM
PropXprt
Feb 17, 2003 07:09 PM
NVR2L8
13
Jul 29, 2001 01:47 AM
