14 tooth sprocket for Warrior
Old Nov 5, 2000 | 09:52 AM
nigman's Avatar
Has anybody put a 14 tooth sprocket on a Warrior. If so let me know what the results were.
Old Nov 5, 2000 | 05:44 PM
hot_shoe_cv's Avatar
The results depend on the tire size you're running now. If you have the OEM tires, a 14T will give you somewhat taller gearing. If you're running 20" tires, a 14 T will restore the original gearing somewhat.
Old Nov 6, 2000 | 06:55 PM
PC_350_Warrior's Avatar
When I got my 20" Bandit tires I got a 14T to push the top end back up to stock. The other day I put on a 15T and its great! Most of the places I ride I top out pretty easily, so the 15T really helps. My Warrior is stock except a White Brothers E-Series pipe, Bandits all around, and a Pro Flow Pro Design filter kit. My bike pulls the 15T great, BIG noticeable difference.
Old Nov 7, 2000 | 02:09 AM
Mohs87Warrior's Avatar
I believe stock is 13T and I run the 14T with 22" rears. I did it because 1st gear seemmed to low, I could just as easily stated in 2nd. Now the gearing seems better for the woods. It tops out at 66mph with a rather stock engine and exhaust. I like the taller gearing and it is worth the small investment to see if it is right for you.
Mohs87Warrior
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
