carb problems
Old Jan 3, 2006 | 12:46 AM
yamwar002's Avatar
Default carb problems
I have a 2002 warrior. It sat for a long time. Now it will start but only run with throttle. Will not idle. Took the carb apart and cleaned it. What jet should i focus on? Is it the needle or the pilot jet or what? And where is the jet located (dont know which jet is which)? Thanks for the help guys
Old Jan 3, 2006 | 12:53 AM
Daniel631's Avatar
The pilot jet is the one that the idle circuit works off of. I've cleaned warrior carbs in the past and what I have found with them is that they are a pain. My advise to you is to soak it in carb cleaner for a while and blow it out with compressed air. That is the only way I have been able to get them to work right. We had a carb bath/washing machine in the shop and putting the carbs in there seemed to be only way to get them clean and working correctly.
Old Jan 3, 2006 | 12:55 AM
yamwar002's Avatar
Thanks a lot . Where is the pilot jet located?
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
