Blaster Clutch (?Cable?)
Old Jan 3, 2006 | 12:59 AM
GarrinChilders's Avatar
Default Blaster Clutch (?Cable?)
When I pull my Clutch lever it doesn't disengage anything. it's like I am not even pulling it. It's adjusted ALL the way out so its as tight as it gets, could it be the cable is stretched out, or the clutch going bad and is a blaster okay to ride with out a clutch (float the gears)>?
Old Jan 3, 2006 | 05:19 PM
fastquad02blaster's Avatar
Follow your cable down to the tranny. Watch to see if the lever it's hooked to is moving or not when you pull it. If it does move, it's your clutch. If it doesn't, it's a broken cable. Cables are really cheap.
Old Jan 3, 2006 | 11:45 PM
fastestkidaround's Avatar
cables are $14 from a local dealer or for fancy ones like motion pro are around $18 to 25.
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
