Need help on kids eton rxl 50
Old Jan 3, 2006 | 05:11 PM
rkostan's Avatar
Default Need help on kids eton rxl 50
My daughter was riding her eton rxl 50 it was running fine till she shut it off to take a brake for a bit. when she went back out to ride, it would not start. I pulled the plug and it had no fire I put a new plug in and still no fire I tore it down and when I put a meter to the coil I get a reading in reverse if I swap the leads around then I get a reading of a positive. Could some on please give me some Ideas on what could be wrong CDI, Stator ect.
Thanks Ryan
Old Jan 3, 2006 | 08:10 PM
smb05's Avatar
Best thing to do is start with the easy stuff first. Clean the quad then check and clean all electrical connections. Make sure none of the connections have any moisture or any corrosion on them. Once you have done that then you can start to diagnose the other components (IE. coil, sator, CDI).
Old Jan 4, 2006 | 04:51 PM
husky100's Avatar
That was great advice given earlier. I would add one thing to that and that is check the kill switch, the one that has the teather if yours is so equiped. I work on after market quads for extra income and have for about 15 years. I come across this problem alot. Parents wrap up the kill rope and it vibrates loose. May be a cause thats simple, if not start with the what is the simplest and work backwards. Hope this helps!!!
ultangler
Nov 30, 2024 01:35 AM
Robinhood
Dec 26, 2015 10:28 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
Minimod
Sep 10, 2015 09:20 PM
