Warrior Snow plow
NEW RECORD 2 POSTS!!!!
also, i have seen people use plows out of RMATV with the hand way of raising and just using U-Bolts to attach the plow to the bottom side on the frame.
Yes it is possible. I have just completed a custom install on my 95 warrior. I used a plow from a lawn tractor and made a custom mount bracket that bolts up where the stock motor gaurd is. I installed a winch (EBAY)for lifting and lowering the plow(custom bracket on front bumper mounts) only payed $21.50 for it. I also have gotten new rear tires off the bay, they work awsome in the snow. I am using three deck post blocks for extra weight on my rear rack. If you have a welder and some fabricating skills anything is possible. In all I have about $85.00 into this project and it works and looks great.
By the way ther are a few companies that make snowplow mount brackets for the warriors, you just have to look around. I think TUCKER ROCKY has them. The smaller plows are pretty cheap. If you choose to buy knew stuff You might have about 300-400 into it.
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
