Warrior Snow plow
Old Jan 3, 2006 | 10:04 PM
YamahaRider8998's Avatar
Default Warrior Snow plow
Does anyone know if it is possible to plow snow with a warrior, do u need chains
Also where would u be able to find a plow for a warrior
thnx
steve
Old Jan 3, 2006 | 10:07 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
NEW RECORD 2 POSTS!!!!
also, i have seen people use plows out of RMATV with the hand way of raising and just using U-Bolts to attach the plow to the bottom side on the frame.
Old Jan 4, 2006 | 12:52 AM
capristang's Avatar
Yes it is possible. I have just completed a custom install on my 95 warrior. I used a plow from a lawn tractor and made a custom mount bracket that bolts up where the stock motor gaurd is. I installed a winch (EBAY)for lifting and lowering the plow(custom bracket on front bumper mounts) only payed $21.50 for it. I also have gotten new rear tires off the bay, they work awsome in the snow. I am using three deck post blocks for extra weight on my rear rack. If you have a welder and some fabricating skills anything is possible. In all I have about $85.00 into this project and it works and looks great.
Old Jan 4, 2006 | 12:55 AM
capristang's Avatar
By the way ther are a few companies that make snowplow mount brackets for the warriors, you just have to look around. I think TUCKER ROCKY has them. The smaller plows are pretty cheap. If you choose to buy knew stuff You might have about 300-400 into it.
Old Jan 4, 2006 | 01:00 AM
Starky's Avatar
Yes, you can do it and you will definately need chains. It will also be hard to turn because there is no weight on the front of the quad.
Old Jan 8, 2006 | 06:01 PM
trialsrider172's Avatar
personally, it sounds like alotta strain to put on this machine, but, if u only get a few inches of snow at a time, it might be pritty good.
Old Jan 8, 2006 | 08:06 PM
5spdvinsn's Avatar
Seems like gearing your warrior down would help with heavier loads. But I suppose it depends on your riding style.
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
