HELP..!!!
Old Jan 6, 2006 | 12:30 PM
chirochris's Avatar
Default HELP..!!!
trying to do front bearings on 350x...cant get the front tire off to pull the bearings out..
i must be doing something wrong..misssing something..
i took the four botls out that hold it on the forks opposite the brake and the break caliper off...but what else ...this thing is still on the forks and the axle wont budge!..
i looked at a schematic but cant understand what is a bolt or screw...
Old Jan 6, 2006 | 06:55 PM
rfwlll's Avatar
Default HELP..!!!
Hi chiro. It has been a long time since I have messed with the 3 wheelers, so I will make a call tomorrow to a freind who owns a shop and I will try to make it over to my cousins house who also has a 350x and I will look at it to see if I can help. I would imagine if you have removed everything that can be removed then it should come off. Maybe trying to spread the forks just a bit might help? Keep this updated and good luck. By the way if you ever need an engine let me know because I have an extra that I never finished rebuilding and it only needs 1 crank bearing, 2 countershaft bearings and 1 bearing in the transmission. Those bearings aren't really that bad I just wanted to replace them because they were not 100% perfect. RUSS[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 7, 2006 | 11:37 PM
ThrashAndCrash's Avatar
Default HELP..!!!
I was gone thismorning when you posted this.......did you get it?
Old Jan 8, 2006 | 11:53 AM
chirochris's Avatar
Default HELP..!!!
yeah got it but the outer race was fused to the hub of one side...couldnt get it off..took to 3 places and a machinist and nobody could get it..so i bought a hub from ebay and said screw it
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
cdstang
Aug 31, 2015 07:52 AM
jaime511
Jul 19, 2015 01:58 PM
newguy230
Aug 20, 2000 08:48 PM
